I tested my egr solenoid(white dot) and with a hand vacuum pump and a 9 volt battery.
The results I got are: vacuum on front port, 9 volt to the solenoid it does not click/open until the vacuum drops to zero.
Does anyone have specs or know if this correct.
If you power up the solenoid with 9 volt first and than vacuum it flows through.
Thanks,Paul.
Thanks,Paul.
