Is the truck (engine and transmisson) up to operating temp? Mine won't engage until the ECT is at least 155* and the trans temp is at least 110*.op2:changed out programmer for another one no difference and i see no difference when changing the levels in the programmer with the monitor.
My guess is that one of the pins in the connectors under the hood is not making contact. Look into the connectors and see if anything looks displaced. If so, straighten it out and it will probably work fine.changed out programmer for another one no difference and i see no difference when changing the levels in the programmer with the monitor.
