hookedup50
I have replaced everthing under the hood engine IP and drove it for a couple of hundred miles. Got air and fuel leak and got 1214 code. I got rid of leaks. My tdc offset is -3.7 on mt2500 with actuall timin g at 13. I went to remove the code to do koko relearn. Did relearn and now have 20 dtc's. I'm thinking I have a ground problem for all these codes to show up. The pcm says it has data interuption and the sensors say the same thing values to high/low simultaneously. Does this sound like the issue?
