ccfoshee
All:
Just finished rebuilding and installing my engine to include a new IP and remote PMD with cooler - which came with a #9 resistor.
It will start quite easily even in the cold (I am in Ohio), however, it white smokes terribly until warm.
Also, I have the following three codes that I am unable to clear:
34 - Injection timing stepper motor fault
56 - Injection pump calibration resistor error
88 - Top dead center offset problem
I tried to clear the DTCs using both GMTDScan and the pedal method and they instantly come back.
I started with the IP straight up and then knocked it toward the driver's side just a hair to get it to start easier.
Questions:
Is the #9 resistor a source of my problems?
Do y'all have any suggestions on my situation?
Thanks for any and all help.
Questions:
