3500_6.5
I am looking for more information on the DS4 pump. I am in the process of trying to build a 6.5 and before starting the build I talked with several of the reputable 6.5 builders out there (Heath and Peninsular Diesel mainly). Peninsular said max output of their DB2 pump was around 310-315hp. Heath said the DS4 could put out more fuel than the DB2 and that if I was wanting more power than the 300hp mark, then I should stick with the DS4. I was hoping for the 400hp range so Peninsular's DB2 was out of the question. Heath mentioned his soon to be released Merlin Pump and his Stage 3 Performance kit that is supposed to put the 6.5 at around 415 hp. I prefer to build my own truck and not use a kit, and I can get most the parts for a lot cheaper than Heath sells them for.
I began looking around (and have been since last August) and found claims all over the board for max ouput of a stock DS4. I have heard/read anywhere from 80mm3 up to a little over 120mm3 as max outputs. 80mm3 wont cut it, but 120mm3 is right around what I was looking for. From my understanding, the limiting factor is the ecm and not the pump? Or maybe both? So, before I go dumping too much time and money into trying to get max capabilities from the pump, I am wondering if anyone has any concrete proof or certainty of what a stock DS4 is actually mechanically capable of flowing. I would like to keep the truck electronic, but if its not possible to get the output out of a DS4 that I am wanting, without buying a $7000+ kit, then I will be going with a mechanical pump that I found that is flow tested to reach the outputs that I was looking for.
I have already done a lot of the upgrades I was planning, and still have other things to be done-including an Optimizer long block. All the upgrades I have done so far though can be used with a mechanical set up as well as the electronic set up, except my current tune obviously. So as of right now I am not too deep into the DS4 build to bail out of it if need be. Just hoping some of you have had enough time/experience with these pumps/tunes to know what the pumps actual limits are and whether or not I am wasting my time trying to reach my goals with the stock DS4 pump. If its just a tuning issue that it sounds like it might be, I am hoping a computer programmer friend of mine (well, sort of a friend...) would be able to help out with that... but that might lead to more $$$ than I am wanting/capable of spending at this time and, as far as I know, could just end up being a big waste of time and money. Any help or input is greatly appreciated!
