DRW front brakes on a SRW truck?
OrionThade
Orem, Utah
Anyone see any issue running a set of dually calipers and rotors on an SRW?
I'm doing an unplanned brake job and got the rotors on before I realized they were for the dually and not the SRW. I really don't want to take the rotors off, so I'm wondering what the consensus is on just running dually front brakes.
The rotors are thicker on the DRW set. Went ahead and exchanged the calipers and put it back together. Works like a champ. Truck hasn't stopped this well since I've had it. The passenger side caliper has always been tight, causing a noticeable pull when I'd stop. That's resolved now.
They're a bit longer and they felt a bit heavier. I didn't measure them against the others, but the pistons seemed to be a larger diameter than the SRW set.
