My drive shaft yoke/transfer case seal is leaking at the seal. I replaced the seal and it continues to leak. I had a drive shaft rebuilt and balanced. (original to the truck after sitting around.) The one I was using was too short and I tossed the entire thing. The yoke on it had a gouge where the seal should have been running, but, was running 2" up. It did not leak but vibrated and ate the U-Joints after 50K - not bad life really.
They cleaned up the light rust from the yoke that I am using now. It leaked the 2nd day and the new seal did not last much longer.
Do I replace the yoke and seal or do I need to possibly repair the bearing in the transfer case as well? I am thinking the rust clean up is ruining the seals?
