Drive from GA to CA
Bagofdimes
Recruit
So far, I have made it to Boonville, MO from Atlanta on my way to Sacramento.
I was playing with the Juice between fuelings to see what the best mileage I can get is. First, I had it set on level 2 with the low boost fueling set at 5. My mileage was 12.9. Next tank, I set it to level 2 with low boost fueling set at 1. The mileage went to 11.2. It was a bit more windy on the low mileage setting, but they are pretty close to me.
What settings do you guys use for best mileage?(without putting to much power to it)
I stopped at Love's and got weighed. My steer axle was 3720, Drive was 5300, Trailer was 7100, and total was 16120. It's a bit lighter than I guessed.
I'm using an Equalizer hitch. Working flawlessly so far. I couldn't imagine this trip without it. The stock hitch is holding up so far...
It has been 95 degrees since I left. My engine temp has been between 192 and 198 up hills. Egt hit 1300 a couple times briefly going up long grades. Tranny has been about 180-190 according to the gauge.
Couple more thousand miles to go...
any updates?
i had mine on level 2 low boost fueling on 3 with a 3600# 18x8.5 x7'h v nose cargo trailer and only got 11 with strong head wind coming home from Texas...:(
Well, I made it to Salt Lake City. One more day of driving should get it.
I got really crappy mileage through Wyoming...8.9:nonod: Lots of grades and lots of wind through there. I don't suspect it will be much better the rest of the way.
Couple of things I forgot above. My tire pressure is 70 in the rear and 60 in front. Also have a modified airbox with a K&N filter. Another thing I forgot that might affect it a bit...My speedo is not set for 285's. Technically, that should help albeit a tiny bit.
