Any tips on fixing sticky door locks using the key;
and interior handel that won't open the door. (searched all over and couldn' find any info).
The door handle problem could be caused by a stretched actuater rod,[there are some bends in it] broken handle lever or a disconnect at either end. you will have to take the door panel off to investigate.
The door handle breaking is a common problem on these trucks. I have replaced 2, one on my old '95 and one on my current truck. Advance Auto Parts has them for about $15. I think they are on the "HELP" rack. Make sure you have a rivet gun because it is riveted in place.
I always just drill out the rivet and replace with a large self tapping screw. I guess a bolt and lock washer would also work.....or just rivet the sucker like you said hahaha.
That white metal GM uses is a joke for something as important as a door handle.
I did the same thing BUT bought my interior handle at the Stealership.
