treegump
Romans 3:22-24
Thinking of building something like this:
But...since I have a gooseneck hitch, it'll be on either side. I'll have a cover for the middle and just use that for shovels, axes, etc. And I think I'm going to put a sheet of metal between the lid and an additional layer of plywood on top that'll slide out if I want to extend my bed... Either way, the protective top (whatever it will be) will be bolted so someone would have to struggle to get to my tools. It probably won't be this deep, but who knows.
Since I'll be taking some depth away from my bed by building this, I think I'll go ahead and build some bed sides, that'll stay in the bed till I need them. I'm planning on building my own headache rack, so the sides and rear will just be an addition to what I was already going to build. But, when I haul firewood, it'll be nice to get a full load in.
My 2 biggest concerns are weight capacity and weather-proofing. I don't think weather-proofing will be a huge problem, as long as I make sure I caulk the outer shell. And I don't think I'll have to worry about weight capacity either, because it'll be a box. Each drawer will probably only be 16"-20" wide, with a 2x? on end for the walls of the box. (4) 2x? with at least 1 layer of plywood on top, not suspended anywhere should be fine... I've never seen a 2x? flatten from any forces, especially if there isn't any suspended sections. I'd draw something, but it may have to wait till I actually build it. I need to find my deepest box to figure out how deep I want to make the storage...
