turbonator
6.2/6.5L Main Bearing Girdle
________________________________________
We have had a few request lately for pics of our ''Pugg girdle'', so we decided to set up a new thread specifically for this..... as of now we have just over 1000 miles on the ''Pugg'' and are able to boost with over 20 psi with seemingly no ill effects (other than lots of power, that is....).
We built our girdle using 1.5 X 2.0'' X 3/8'' angle iron, this should be reduced to 1.5 X 1.5'', to eliminate material removal. It was just cut with regular cut-off wheels and a grinder, then hand filed for fit and finish.
Unfortunately my measurements were just on the side of a cardboard box and was misplaced, so we have only a pattern to work with now for future girdles.
This is a drawing made by MaxPf, please note that our girdle was machined to fit a stock oil pan(6.2L, 6.5L and hummer pans) the drawing requires a custom pan, yet the center to center bolt measurements are what you need most.
The military pan we used, had the oil dipstick .200'' further on the side of the pan, so a minor adjustment was all that was needed to be able to use all available oil pans for these motors.
Well I've babbled on enough here, time now for pics.......
