dbrannon79
I'm getting there!
Hey guys, I have been wanting to find a way to add a tablet screen in our trucks that would be able to read sensor data, record data, and display some informative gauges and other info straight from the PCM on our trucks similar to how Torque pro does for the obd2 systems.
a friend and member here mentioned that ALDLdroid will read the data and record data the same as the tunerpro rt does on a windows pc will using the same definitions files. the data is also compatible to be read between both apps. one being for android and the other for a windows pc. this is awesome info.
I have managed to scourer the WWW and have collected all the needed files to make this happen. I have tested it on tunerpro rt and it works, still needs a little tweaking here and there, but is functional.
something that both of these applications won't do is read the data and display your real time and average mpg's, as least not that I am aware of...
what I am wanting to do is find a few gurus that might be able to use the coding that ADLdroid uses and create an app that will take the fuel rate in mm^3 along with the vehicle speed and other needed data to show a display for both average and real time mpg.
I read a post on DP that explains the fuel rate in mm^3 and how injector balance effects it, but I don't think our obd1 pcm shows the injector balance data.
to my understanding the fuel rate shown in the pcm data is for all 8 cylinders combined and per second. taking the fuel rate reading from the pcm with the speed, miles driven, and possibly run and idle time one could come up with a formula to calculate mpg.
I have yet to get my hands on an android tablet that has "USB-OTG" usb one the go meaning that one can connect a mouse or keyboard to the tablet and it would work out of the box. this is needed to connect the truck to the tablet to read data. I may even go a step further and use that tablet in the place of my radio head unit to combine the use of music and gps navigation as well.
Y'all give me your thoughts on this and if anyone wants to join in on this venture let me know.
