FellowTraveler
Not to jack other threads I figured lets talk about available heads and maybe get a better idea of what is available.
Cooling has haunted the GM 6.2/6.5 platform which is related because that is what mostly causes head and block failures, however that is a much different topic. Any cooling mods on this platform should include waterless coolant to eliminate steaming and cavitation.
Let's leave complex and labor intense porting out of this conversation as we already have a string for that keep it simple.
Generally, the IDI diesel is not a high RPM design so in order to increase volumetric efficiency (VE) blowers or turbos are used.
The 1982 6.2 "J" cylinder head has the biggest valves and is billed as great flowing for OEM. Valve sizes are 1.96" & 1.63". Heath uses these sized valves in his performance build.
The 6.5 applications go with 1.81" & 1.53".
I posted the question as to what sizes are the P400's valves and it appears no on one knows.
Constructive input is welcomed.
