dieing
chevyCowboy
Springfield Nebraska
ok guys heres my problem
about 2 weeks ago i noticed when the truck was cold, when i first started it up it would run fine but if i say had to stomp on it to get out in traffic it would die when i pushed clutch in. so i grabed the next gear and let the clutch out and she started right up. now this goes away once the motor gets up over 120* or so. i was thinking it may have had something to do with the fact that i havent changed fuel filters in a while changed it out yesterday. i pulled the filter and down in the bottom of the housing there was alot of nasty stuff and on the filter there where some pices of rust. im gessing from the tank. got it all cleaned out and reprimed and fired her up and she still dies untill warmed up
any ideas
just remembered i think this stared happening after i took the oil cooler off and pluged the holes in the block (had a bad leak and was waiting on leroy to see if his kit would work with 4x4 ordering new cooler very soon)could this have any thing to do with my problem seems like it wouldnt to me but all the info helps
Do the lift pump test and put some good fuel conditioner in it, Sea Foam or Lucas easy to find, Lucas would probably be better for this problem.
Did you turn up the fuel yet?
no havent turned it up yet. i was thinking it dosnt do it all the time and when it dose its like it looses fuel or has air in the system. could i have an injector leaking down? iv been noticing the smell or raw fuel sometimes when the truck is off and its been setting for a bit
LP runns great when ops in jumped used that to blead the air out when i changed filter but i dont know if the ops will make it run
i will try and do the check list tomorow i was going to tonite but didnt have time seeming as it is very long
so i guess no one has any idea darn my luck having such a wired problem and its intermitent as well which makes it harder to figure out
When the truck is cold/warm, she dies when you step on the clutch to change gears?
Is that what your saying?........Sorry, but i'm not quite understanding from your written description of the problem.
Dude, do the lift pump test. Crank the truck and open the water drain with the engine running, if the engine stays running for 15 seconds you have other problems.
If it passes the lift pump test, put a double dose of lucas in the fuel. If that dont fix it, new IP time or live with it.
Whats the idle set at.
ya thats when i notoce it. it only does it when i rev higher than 3000 and its not every time. sorry its a hard problem to describe
[/URL]
ok ill try that tomorow. are you talking bout this from lucas http://www.lucasoil.com/products/di...=8&loc=show&headTitle= - Lucas Fuel Treatment
and thats another problem when the truck is cold it idles at around 800rpm and when its warm it is closer to 1000rpm
- Year: __93____
- Truck model and class (ie: c2500) ___k2500______
- Automatic or Standard ___standard_______
- Mileage: (indicate miles or km) __258000_______
- Replaced parts and mods (IP, PMD, chip/PCM, TM, injectors etc) ___wg wired shut, ho water pump.________
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? _____f_________
- Ambient outside temp: (indicate *C or *F) __80*-90* most days________
- What fuel are you using? (#1 Diesel, #2 Diesel, Bio, VO, WVO, etc) __#2_______
- What fuel additives are you using? ____none at the moment_______
- Where are you located? ___neb__________
- Air filter ___250K____3/09__
- Fuel filter ___258K___7/09___
- CDR Valve? ___229K__2/08____
- Coolant – last flushed/replaced at _______256K_4/09_____
- Oil – synthetic/regular, changed at ___rotella 15w40________
- Batteries – state of charge, (matched set) replaced at __replaced diehard platnum 3/09 good charge___________
- Battery cables and grounds (removed, cleaned and tightened): ____check 3/09__________
- Glow Plugs - how many miles on them? ___?______ What type? ______?_______
- Injectors - last changed at _____stock replacements 192K by po__________
- What were you doing when it happened? ____accelerating__________
- How was the truck running fine before this problem appeared? ___good__________
- Has this problem ever happened before? _______no________________
- Describe any related factors that might be part of the problem. ______________
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) __N__ And? _______
Diagnostics:
1] Starting:
1a] Does the engine start? _yes________
1b] Does the engine crank over? ___yes_____
1c] Are your batteries fully charged? ___yes______
1d] Have you removed, cleaned, and tightened all battery connections? _yes_______
1e] Does your Wait to Start light come on for a time? How long? ___dont have one______
1f] Does your glow plug light come on? ___8 sec or so______ For how long? _________
1g] Do you see smoke from the exhaust while cranking? What color? ________
4] Stalling Issues
4a] Do you experience stalling only when hot? ___it only stalls when i get into it and rev high (3000) just after it has been started _________
4b] Does it stall under particular circumstances? (ie hit bump, or on accel) _it has never dont it more than once while the truck was keep running and it dosent do it every start up _____
4c] Does pouring cool water over the IP seem to help with restarting? __havent tried_______
4d] Is stalling momentary (engine recovers)? __it will die and has to crank along time to restart_______
4e] Does SES light come on when engine hiccups? ___no______
4f] Does cruise control quit working when engine hiccups? ___never tried it________
4g] Does re-starting seem to reset engine, restoring cruise and power? __havent had happen with cruse on but it runs fine after it has restarted____
4h] Changes to dash lights or instruments during stalling events? ___nothing iv noticed________
5] Running Issues
5a] On cold start, does upper rad hose get hard before engine warms up? ___no____
5b] Any bubbles or oil film in coolant overflow tank? __no_____
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? _____no_____
5d] Excessive white smoke from exhaust on cold start? __yes_______
5e] Excessive black smoke from exhaust under hard acceleration? ___normal_______
6] Performance Issues
6a] Do you have gauges? __yes egt and boost_________
6b] Maximum boost under load? __12-13__________
6c] Have you added a performance PCM (reflash) or Chip? _____na_________
6d] Have you changed exhaust / downpipe / crossover? __yes from ssd 3" dp 4" exs ______________
6e] Wastegate – mechanical or vacuum? ___stock but wired shut___________
7a] Single or dual thermostats? _____single_______
7b] Have you replaced them lately? Manufacturer of replacements? __rep at 228500_______
7c] Have you pulled and cleaned Radiator and coolers lately? ___yes_________
7d] Have you replaced the fan clutch? Manufacturer of replacement? ____no____
7e] (winter) Have you tested your antifreeze? Good to what temp? __________
7f] (winter) Are you using a winter grille cover? ___________
_________________________________
__________________
Skpped all the Lift Pump tests? That is the most important.
Without LP, the IP will have to suck fuel all the way. So IP may be bad.
Just a warning.
just went out and did the LP test started truck running fine opend water drain and after a little bit it died hard to get restarted like when i had air in the lines. poped ops connector of a jumpered the lp with blead screw open heard lp running took a bit for fuel to come out but when it did it was flowing good im thinking i got a bad OPS but i changed it a couple months ago wiht one from Napa
hope i gave you guys better info this time
Just a warning.
it said if not running so i didnt fill those out my bad see my last post i did check the lp
2a] Can you hear your lift pump working? ____no________
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? ___no only a little steam not like it used to be when i drained the water______
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? ___some________
2d] Loosen an injector line and crank the engine - does fuel come out? __yes ______
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? __yes_________
Napa's OPS replacment are not up to spec with OEM (AC-Delco) and are a known weak link. With that being said, get a GM Oil Pressure switch/sender, also you might want to do the OPS (relay) modification, (check the stickeys) found in the DIY section.
went to the dealer this am got an acdeclo ops and have not had a problem sence. i now get a good stream of fuel from water drain. and the truck also seems to ideal smother and now that i think about it iwas experincing hicups ocasionally before and they are gone now as well so thanks to you guys and who ever craeted the check list if i had just started with that i could have fixed this last week
thanks again guys
