I was looking on DP about the use of Dextron VI in 03 Allison trans. Some of the posts and a link to an Allison service bulletin made me believe that it is not OK to use Dextron VI in the earlier trans.
One thread says that two seals in the trans (shaft output and one other seal) will harden with the use of Dextron VI and can start leaking.
I am not positive but I think I put Dextron VI in my trans when I changed the fluid a while back. I have had a leak that looked like it was coming from the weap hole at the trans and engine mount flange (bell housing). I thought it was coolant but it also bears a strong resemblance to trans fluid.
This info is beginning to make me wonder about the source. Funny thing is after all the leak spots it has stopped leaking for now.
Is the Dextron backwards compatible? Would there be a problem if I were to change to syn. fluid?
What do you think it cost if I was to go to an Allison dealer and have the trans overhauled. I suspect that I may have some clutches slipping.
