Trying to decide what one to go with. Actually on both the 1993 4x4 with the Yank and the MT Dodge.
The 1993 sunk a side to the axle in dirt while trying to pull a gravel loaded trailer. The Thermo 4x4 actuator decided to die after 20 years and 200K miles and had to have the truck/trailer be pulled out. Fixed since. If it has a G80 it quit long ago. The rear having a locker or LSD may have pulled it through. It's got a high stall converter and doughnuts (Adult driven no abuse here) are highly likely. Needs the best off road traction. A G80 clearly would depart through the cover with the Yank stalled up... I am leaning toward a Locker for this one. Rear end needs a rebuild due to howl anyway.
The Dodge is a 2WD and will fishtail under heavy power in 4th gear with a trailer on wet roads. Has an open diff now. Major concern is a grade and getting a wheel in the gravel like a driveway. It needs help in the traction department. I am leaning toward Truetrac for better street manners. Word is the factory unit is similar but not as aggressive aka sucks. No off road planned.
Snow and Ice is not a factor, but, wet roads are.
