bigchevy89
Can any body tell me how you would check the timing on the mech pump?
I would like to advance the timing in my 93 3500.
No. Advancing the timing = more rattle. Try activating the cold start, that is 3 degrees advanced. That is one reason it rattles so much when cold.I think i will just have to give a try. if i advance the timing right the rattle should be less
When i set my 6.2s timing all i did was bump the IP mark a hair to the driver's side.
Like so.
That's on the old IP, but the timing marks are pretty much the same on the new one.
yeah, as I was driving home, i realized I had a brain fart.
Thanks for clarifying
What distance is that between the marks 1/16 of an inch or less? Hard to tell in the pic.
did you notice any power improvment?
