Overthedge21
- Messages
- 3
- Reaction score
- 1
Got recommended to this forum for some help on my issue. I picked up an 87 K30 a few months back with a blown 6.2 in it. Thing ran great with the exception of a cylinder that wouldn't fire due to a bad piston and cylinder bore. So I pulled it and took the pump and accessories off and scrapped the block. According to the 6.5 db2 conversion manual I found on here, it's supposed to just be a straight forward pump for pump swap. So I picked up a cheap 97+ 6.5 that got pulled for a bad DS4. Did a compression check and got a low of 350-370 psi on one or two cylinders, all the rest were up around 420, which I think is enough to run on all 8 right? Or am I stupid and is this the basis of my issue? Anyway, with the engine up onna home made test stand I stripped it down, pulled the heads and inspected the cylinders, put in new head gaskets and dropped in a set of ARP studs. Swapped the db2 onto it, times it all according to the timing marks, and haven't once been able to get it to run nicely. I'll attach a link to a video of it, the only way I was even able to get it to run like that was to advance the pump drive gear 2 teeth on the cam gear, thing wouldnt even start when the dots were lined up. This is as close to good running as I can get it, looking to see if anyone has any ideas. I plan on swapping in a cummins eventually for power and reliability since it's gonna be service truck/tow rig, but I wanted the 6.5 for now as a an easy drop in replacement to get it on the road and slowly collect parts for a swap maybe next year. So if anyone has any ideas I'm open to them, cuz I'm drawing a blank here
