Just adjusted the idle down from 1100 RPM on my 93 project truck. Cruise control cable too tight was holding the idle too high I found. Sticker says 700 RPM, 800 cold. Have it at 850 cold with cold advance and 750 RPM warmed up. Checked the cold advance was off during hot adjustment.
After letting the truck sit hot it will start and hold 400 RPM or less. Bumping the throttle does not help it get the idle back when released. After running some the idle speed is back to where it needs to be.
Is there a low speed (idle) governor on the DB2?
What is causing this? Worn IP? Bad injectors?
