Sunshine
Northern Lights
There is a guy over here says its best to makes larger holes in the Cylinder Head Gasket that are face to face to the cooling channels as they are under dimensioned,as these 6 small holes can get block with un-clean cooling fluid.
Has anyone at DTR done this mod to those 6 small holes?
He also feels that how many thermostats you have or how larger water pump you put on your Truck,its doesn't help if holes are not enlarged.
