sspence65
Problem: Cranks but won’t fire
- Year: 1996
- Truck model and class (ie: c2500) Suburban
- Automatic or Standard Automatic
- Mileage: (indicate miles or km) 250k
- Replaced parts and mods (IP, PMD, chip/PCM, TM, injectors etc) original
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? Turbo
- Ambient outside temp: (indicate *C or *F) 50F
- What fuel are you using? (#1 Diesel, #2 Diesel, Bio, VO, WVO, etc) #2 diesel
- What fuel additives are you using? none
- Where are you located? andrews sc
- Air filter K&N Cleanable
- Fuel filter 5000 miles ago
- CDR Valve? ?
- Coolant – last flushed/replaced at 10k ago
- Oil – synthetic/regular, changed at 3k ago (regular)
- Batteries – state of charge, (matched set) replaced at good
- Battery cables and grounds (removed, cleaned and tightened): new
- Glow Plugs - how many miles on them? ? What type? ?
- Injectors - last changed at ?
- What were you doing when it happened? driving at 30mph, rough road.
- How was the truck running fine before this problem appeared? smooth
- Has this problem ever happened before? no
- Describe any related factors that might be part of the problem. filled tank 30 miles earlier
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) yes And? 251 and 370
Diagnostics:
1] Starting:
1a] Does the engine start? no
1b] Does the engine crank over? yes
1c] Are your batteries fully charged? yes
1d] Have you removed, cleaned, and tightened all battery connections? yes
1e] Does your Wait to Start light come on for a time? How long? 5 second or so
1f] Does your glow plug light come on? no gpl For how long? _________
1g] Do you see smoke from the exhaust while cranking? no What color? ________
1h] Does the Service Engine Light Glow during Start/bulb check? yes
2a] Can you hear your lift pump working? yes
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? yes
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? yes
2d] Loosen an injector line and crank the engine - does fuel come out? no
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? yes
3] PMD / IP Issues
3a] Location of PMD (on pump, on intake, remote mounted) pump
3b] Condition of Extension harness (if used) Vendor or Homemade? _________
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. ?
3d] PMD Make: ?
3e] PMD Age: ?
- Year: 1996
- CDR Valve? ?
Diagnostics:
1] Starting:
3] PMD / IP Issues
3d] PMD Make: ?
3e] PMD Age: ?
