CtChevy427
Fuc*ed over by head admin......
In the past month or so I have been having my CPU usage spiking to 100% or close to that at times. I mainly notice it when I switch between web pages. Any ideas?
most mallware and ad scanners will do that.
task manager will show the process, you can look at it and see who is running hard, my bet would be svhost......if it is XP....Vista could be different, but you can still find out what is causing excessive cpu usage
when I was having that problem I would go into task manager and tell svhost to end process, there are several that run in the background and it involves mostly network usage....mostly different ports that the computer has to gain access tot he internet. More and likely you have someting that is exploiting your internet connection, I never found mine so I saved what i could and reformatted and reinstalled everything. i would get a year or two beofre it would start again......web sites contain harmful stuff and the owners don't even know about it......Tim, you are right I am running XP and svchost.exe is second in line to ybrowser.exe both pulling over 30K. what are they and can they be stopped.
I was using AVG which fights both. Also ran spybot and adware. none have found a thing. Currently running avast with windows defender and nothing has been found. I wonder if running one of these in safe mode would find anything more.
