Well I decided to tackle my leaking cooler lines this weekend. When I talked to the Napa guy a couple weeks ago he said he could make up a couple of hydraulic lines for about $25 each so I figured I'd give that a try since many others have had good luck going this way. I cut the lines loose from the cooler just below the radiator where I planned to use compression fittings. I took the lines out and hauled them to Napa, when he asked me if I wanted the lines a little longer or the same size I thought I may need a little extra so we made them 47 inches.
When I put it together the hydraulic fittings and line take up a lot of room where the filter adapter and filter fit in so I planned to go with a remote filter. Till I get the remote setup I just removed the adapter and left the front drive shaft out. There was a little extra line that kind of dipped down where the skid plate would be just like the factory lines did. Since the hydraulic line is so stiff it was kind of pulling down on the alluminum lines so I bent the lines back up about where they should be. I left the skid plate out and drove it to town and when I got there it had begun to drip so I figured I would have to tighten the compression fittings when I got home. I got home and crawled under it and noticed the leak was running down the line from the cooler. What had happened was that the alluminum lines had cracked at the connector where it goes into the cooler because of the stress from the new lines pulling down I guess.
I took the connectors out of the cooler and the lines were froze up and just twisted off. The connectors look kind of funky and I'm not sure that the parts store will have such a thing. I guess plan A would be to get new connectors and steel lines to just replace the alluminum and go right back to the compression fittings hoping it would hold up.
