Big T
After I fought with the installation of the Borgeson lower steering column, the dash temp gauge is slow to respond. Like it takes 10 miles to start moving up and eventually reaching its normal operating temp. Previously it would start moving up within 1/2 mile. I also noted that as it is moving up, it will dip downward if I stomp the go pedal. Any ideas here? Did I mess up the coolant sender (again) while jerking around with the steering shaft install?
