Raleigh
So I brought this up in another thread and though maybe it needs its own.
Has anyone installed a coolant recovery tank after the factory coolant tank?
I was thinking about coolant and its relationship with the heat and pressure in the sealed system.
I have read that these blocks and heads are prone to steam pockets and hot spots.
This IMO is due to the low pressure in the sealed coolant system.
A liquid at a given temp, say 200* and under 10# pressure it will never boil.
Take the liquid and temp and place it in a vacuum and you boiling.
That said I think this is a design and engineering problem with the cooling system in our trucks.
The lack of pressure is what causes the steam pockets and hot spots in the engine.
With no recover tank (the factory tank is NOT a recovery tank, it is part of the sealed system) once the system reaches pressure the coolant is expelled and lost.
And it will do this everytime it gets up to pressure, soon there is no pressure in the system and the coolant is allowed to boil.
By adding a coolant recovery tank I have captured that coolant, now when the engine cools it will pull in that coolant rather than air.
Now the engine is always full of coolant, even when it cold.
I replaced the 15# cap with a 13# cap to prevent too much pressure in the system.
Any thoughts on this idea, good or bad?
