I just started developing a coolant leak my upper rad hose was leaking replaced it with a new one just got done work noticed two puddles under the front bumper on the ground moved the truck it was coolant. I wonder if the lower rad hose is stretched out and leaking as it cools down. I never had a leak until recently. Only other thing is a bad rad and I hope it's not. What's the best way to drain the coolant and save it on this rad does the drain have a nipple to put a hose on?
