dtreid
Have a chance to buy a truck...98 Chev 2500 4x4, ext cab, long box, auto, awesome body, 190000kms, original owner.
Owner said that it worked great until coolant started going into the oil, but only if it sat for several days. Had a mechanic pull the heads. Mechanic told him that the block was cracked.
I looked in the cylinders and couldn't see any cracks. Heads have been off for over a year, engine covered with a blanket, but there is some corrosion on several cyl walls.
Want's $1k for it.
Is it worth it? If block is indeed cracked I'm not interested, but is there a chance it's just head gaskets?
Want's $1k for it.
