Acesneights1
Ok, probably got Bobbiemartin's attention for sure. I still have diagnostics to do on my new burb but if the IP for some reason is dead I am seriously considering canning it for a DB2. Here's my thought process. I have a reman db2 sitting on a truck I am going to most likely dismantle, however it is not a 4911. It's the 6.2 one (don't remember the number) will that pump put out enough fuel if I turn it up ? Not looking for performance. If that DB2 turned up can match a stock DS4 tune I would be happy. Also what lines do I use ? AFAIK I would need lines from a 93 6.5TD or a 88+ 6.2 . Any issues with the 6.5TD intake clearing a DB2 ? I don't think there is but here's how I'm doing the math.
To fix with DS4:
DS4=7-800$ for GOOD rebuild(not pensacola crap)
PMD relocate kit 3-400$
Heath Tune so I can loose the vac system=4-500$
So that is min 1400$ and still stuck with the same PIA DS4 System
If I convert USING WHAT I HAVE..:
DB2=free
Lines=???
Compushift standalone controller for trans=11-1200$
I know Bobbie will chime in on a cheaper way to use GM TCM for the 4L80e but I think I would go with the Compushift for ease of install and more veristillty programming the trans.
So I would have a trouble free great running truck for less than replacing the DS4.
The only sacrifice I can see is no cruise control which the Burb currently does not have anyway although if I fix the DS4 or don't need to, I will install cruise.
My experience is the DS4 is a royal PIA. Even with the PMD relocate, D tech etc...They still fail. Even Heath's fails. Mine did after 2 yrs. I have 2 dead d techs on my bench less than 2 yrs old so I am getting a bad taste for the DS4 but I probably wouldn't convert iof I had to buy a DB2 but being that I have a nice reman one, it's seems worth it. My only concern it will a 6.2 DB2 put out enough fuel ?
To fix with DS4:
DB2=free
Lines=???
