schiker
When doing circuit diagnostics for a complete path when does it switch from continuity to an resistance test for a typical DMM?
When using a DMM for determining circuit paths....
Simple pole switch test or same wire test I use continuity test and you can hear a beep if on that function.
But when going over resistances ie a small coil or incadescent light it won't beep because there is a resistance between the two points. Is there a typical ohm value that DMM's quit beeping? I usually use a craftsman DMM and sometimes a Fluke. But is there a general rule. Probably depends on the test voltage of the meter and or battery strength of meter but again is there a typical max ohm value considered continuity?
