Cold Weather Cure
ya know I thought about buying the glow harness but your battery cables won't work for me. I swapped over to top mount batteries. I see the special is buy both but I only want the glow harness. For the most part mine works well except maybe 1-2 plugs not working.
I am not sure if it is the same with the electronic motors if it makes a difference, but I wired in a push button to bypass my glow plug relay on my 1993 using a solenoid off a Ford. Works amazing. 90% of the time my relay does the work but on the extra cold days I can hold my glow plugs on for a little bit longer and it makes such a huge difference. Cost about $50 bucks overall including the battery cables and all that needed but well worth it. I have kept them on for 30 seconds one time and never had a problem. I have upgraded to the 60G's or whatever those good plugs were. I can take a video sometime if you guys want.
