Crazy
Need some help with code P0251 i know what it means but need to know what would make this code pop up
Here what happen truck hipcup a couple of times yesterday put some put Qt cleaner in tank and then on the rest way home the truck started defuel and going in limp mode pull it over to side of road it stall started right back up and ran fine the rest of the day put other 100 miles on easy but when got home i put fuel pressure gauge at the water drain valve and it was reading 4psi at idle that seam low i think but would LP or bad filter set that code off ?
Clear the code and has not come back on yet so far
Need what ever help i can get. Getting ready go on a trip pulling my 5th wheel in few weeks and don"t want be sitting on side of the road
Thanks for any help
Bruce
Thanks for any help
Bruce
