Code 81
Michaeljp86
EVIL GENIUS
MICHIGAN
I started working on the deluxe today. When I clear codes and check them without even starting it I get code 81. When I start it and drive it I still get the same code. The transmission wont shift out of first. I put new solenoids in it and that did nothing. Any ideas what to check?
DTC 81 - Transmission 2-3 Shift Solenoid Circuit
I checked the ground and its fine.
Ive got 2 trucks that are the same so I can swap parts. I parked the other truck for the winter but last I drove it everything worked fine.
you may want to have a look at the tranny trough connector for bad contacts.
could also be bad VSS,they should read within 20 OHM of each other.
I did switch the speed sensors around. Ill check the ohms out. They were supposed to have been changed before I bought the truck. He said he changed them hopeing to fix the problem.
