code 78
hereismylife
formerly j k auto
pa
Ok some reason no matter how I search this the search feature dont want to show me what I am searching...
1. I want to test the vac pump. Vac should be what at pump? and what at waste gate?
2. How do I test the waste gate solenoid?
Thanks
if you have a mighty vac pull suction on the wastegate and see if it will hold it without bleeding off or if vac is up to par you should not be able to move it while idling
Ok checked the volts..good
Checked the vac at pump....good
Checked the selonoid...not good
Replaced and now holds at idle...and no code yet...
thanks for the quick help :)
