mr_goodwrench_06
- Messages
- 106
- Reaction score
- 1
I started noticing that if I sat at a red light in gear with my foot on the clutch for any length of time, the clutch would slowly start to engauge. A week of this and then I noticed the pedal was low and it became increasingly difficult to engauge gears, espcially from neutral. Finally, I could not get it into gear at all from neutral.
I bought a slave cylinder, bled it as instructed and installed it. No change. Very low pedal. Slave cylinder rod movement of about 1 inch.
I bought a master cylinder, installed it and still no change. We bled the system as you would a set of brakes. No change. I tried opening the bleeder port and just allowing fluid to drain out, always keeping the master full, no change.
I took off the slave and would crack the bleeder and force the rod in and then close the bleeder pulling fluid from the master, still no clutch!:sad:
Any sugestions????:mad2:
Thanks,
Bill
Thanks,
Bill
