Mad Maxx
See, what had happened was...
See Post #4
I have 255/85/16s which are about the same height (33.3" tall) as the 285s not as wide though. My tires rub a bit on the valance front bumper, but only when I get the truck on a bind like turning into a parking lot with an incline. Other than that no issues. I 've read about others running 285s and its always the valance that rubs not the sway bars or suspension. Also for the record my suspension is stock ride height. A little trimming on the valance or a turn or two of the torsion bars probably no issues at all.Right now I'm Running 305/35/24 Tires on my Truck, they are Wide but Short. They Rub on my Sway Bar and the Back of the Front Wheel Well when I Turn.
I want to get 285/40/24 Tires when I Order up New ones. The 285's will be a lil bit Taller, but Skinnier.
Would they still Rub due to being Taller than the 305's, or would they NOT Rub because they are Skinnier than the 305's even though they are Taller, but because they are Skinnier, they'd have more Clearance.
