schiker
Mercruiser 3.0 powered SeaRay bowrider. Uhhhggg, has it been that long since I took this thing out? Well time flies when you have 2 kids under 4 yrs old and no time for the boat.
When I put it up to winterize it I bought non ethanol premium fuel, added marine stabilzer, and fogged the carb/engine with marine engine fogger. But I want to clean the tank out and add fresh gas to the tank. So I took the line off to the fuel pump and siphoned out as much gas as I could through the gas pickup. The gas actually appeared pretty good still clearish not as cruddy as old stale gas as I have seen before that has sat.
But I bet the last bit in the tank might not be as good looking. I plan on adding a gallon or 3 of fresh fuel with a fuel drier additive, seafoam, and or Starbrite starton additive let it sit while I wash and clean up the boat better and prep gear etc then siphon out this purging gas.
Then to crank it up I will add a few gallons of new fresh gas with the appropriate amounts of seafoam and stabilzer to start this thing up tomorrow I hope.
Does that sound like a good plan? Any suggestions to improve it suggestion for product to add to the tank for purging and cleaning? Taking out the tank and really forcefully cleaning it is not something I want to do. The boat was stored inside a garage with a cover over it since it was ran last so I don't think the tank is awful just old stale gas in the tank and maybe some water (the gas station advertised non ethanol fuel but who knows for sure again it did look good for 2 year old gas).
