NVW
This is on a Patrick Forklift with a Chrysler charging system from the 70's to 80's with the transistor volt reg.
I have ign volts to the ign terminal of the voltage regulator through to one brush terminal, the other brush also reads the same volts. The alt. is good, If I ground out the second field terminal(brush), it charges. I've tried another used alt and a new one. All three will charge with the grounding of the field terminal.
Everything points to the v reg, I've bought two new ones and still no charge. Could the new "Made in China" v reg's be NFG?
Am I missing something else, I know there is a Ballast Resistor but does it have a function for the charging or just the ign. coil?
