Via a lab performed Used Oil Analysis? Just looking at oil won't tell you unless it's major amounts.No oil hasn't had any antifreeze in it.
I'll have to do that after I replace the oil cooler lines.Don't talk about it, just send an oil sample to Blackstone Labs. It's a good idea to do samples periodically anyway. You can catch things you didn't know were going wrong before they are a catastrophe with oil samples
No that's the first time I seen it I mean I just got the truck but the stuff was waxey feeling and smelled like oil I am slightly high on oil.There are other things that could cause the discoloration. Is this something you normally see at certain intervals, or just now? Copper, yes, and water. Along with different waxes (c25-c50) that could get there via oil/fuel break down. What fuel do you run-what bio mix if #2 (on pump label). If you have a small sample like that left, place it on a steel plate and attempt to ignite it with a cigarette lighter. If it melts and reconstitutes it is a petroleum wax, and no worries. If it will ignite, it is fuel derived and can indicate fuel washing out into the oil pan. If it spatters then you are dealing with water. If it goes more fluid, and darkens to a deep green, then that is the copper breaking down in the oil and indicates a high acidic level of oil(not good for bearings) This is just if you really want to chase down what it is. Regardless, it all needs to go.
If you cant send it out now, and are forced to drive the vehicle, I would at least change the oil and filter, save a sample into a clean container for testing later. Get it out of there sooner rather than later. Wash the cdr with diesel and dry it out. Pour back in a touch of engine oil to "rinse" the diesel.
I will but for know I'll keep an eye on the coolant level. What's a good company to send the oil to.Adding to the chorus of getting an analysis of the oil.
My last motor went from awesome to trash in just 10K miles and had to replace it due to coolant contamination. Had I done an analysis at the 5K mark, am highly confident I could have salvaged the old motor. Old motor sounded great, had good pressure, and still got reasonable mileage.
Ok I'll have to check it out like I said I know I put to much oil in and the truck sat for a month when it was getting body work and I haven't seen any coolant consumption.Blackstone or Oil Analyzers are the ones that get the most attention.
. . . what do you mean by I don't need to change the oil once I take the drain plug out its draining. . .
