Car-Code Cylinder SHut-Off
Matt Bachand
Depends on the 6.5
Worcester, MA
I see the options to on/off/disable individual injectors, but when I select them it doesn't seem like its having any effect.
Anyone else with car-code get this to work?
I've done it with a Tech II under the "injector balancer test" choice.
It did make a difference on my truck. Every injector i shut off, was like cracking that cylinder's injector line, it caused a dead miss until i "turned on" that injector again.
yes I have . Have you downloaded Quomacks pdf on how to do a TDCO? When your in that mode you can access it.
