Problem Child
Non Diesel mechanic
My 95 6.5 4x4 Suburban was running so good and then she just died going down the road. I’m familiar with the PDM shutting down but usually she would crank back up. Mine is the updated Leroy driver and it’s located behind the front license plate.
This time she wouldn’t start back but would spin over fine. I had her towed home and was going to check codes with the jumper the next morning. The check engine light wouldn’t come on much less flash a code. I did smell a little burning smell after she died but couldn’t locate anything.
I’ve already purchased a new ECM but I’m only guessing that’s what is wrong. Before I install the new computer, is there anything I should check and do y’all think it’s the ECM at all ??
