bobbiemartin
Author of The DB2 Conversion Guide
I have been corresponding with several 6.5 gurus and I'm still not 100% sure on the cam bearing oil hole orientation.
On the front bearing, the factory manual says the oil holes need to be at 1:00 and 4:30, although the Military manual says 12 and 4 - so I would say they are reasonably close.
They both say there should be a notch in #1 cam bearing facing out, but my replacement Mahle bearings do not have a notch and I'm told most aftermarket bearings do not have the notch.
On the remaining cam bearings, there is only one hole. The military manual says to install the oil hole at 4:00 (it actually says to install at 10:00 with the block inverted, which is 4:00 when upright)
Some of the factory manuals say oil holes at 1:00. Others say to align with oil feed holes. There is an oil feed hole at 6:00, but I do not think this is the correct orientation.
Any input or other documentation would be appreciated. Also, if you have replaced the cam bearings, did they have a notch in the #1 bearing?
