C/K Cab Clearance lights install
GM Guy
Manual Trans. 2WD Enthusiast
NW Kansas and SC Idaho
I am looking to install a set of 5 factory (or factory equal) clearance lights on my half ton in sig.
I want to not blow too much $, but if GM is the only good way to go I'll consider. I also want just factory style, no smoked, function, not form.
Is there any kits that are of good quality that won't leak? (LMC Truck kits???) or is there any others? I also would like minimal splicing, but if that is the better way to do it, then i will.
Any advice appreciated, thank you!
i bought a set of stock 99-07.5 cab lights to put on my 93 half ton. will post pics after i get done painting it. i bought oe's
