millsroger
Went out yesterday on the back roads and did some "let's see how this does" kinda playing around with my sig truck. Tires are stock size, semi-agressive M/S tread and near new.
Has alot of axle hop in 2WD when it breaks loose under torque. Has the LS / lock up rear end and I am not sure how these work.
Truck was empty so I don't think it's from spring wrap up cause of the rating. Ride on the washboards etc. is quite good with very little tail end skitter in the turns even in 2WD.
In 4WD over the same road, under enough torque to break it loose it will try to bunny hop a bit.
Need some help from mudders and pullers out there.
