serluk63
Help. Anybody. Suburban 2500 4x4. Some times roll and accelerates fine. But sometimes, as if someone is holding him. Slowly accelerates, poorly kept road. At first I thought that faulty brake hydro booster, changed it, replacing fluid like feel better, but then things got bad. I changed the wheel hub, brake discs, brake master cylinder, caliper, Ball joints. bushings. Bleed the brake booster, brake has blended. I changed what I could. The engine is working properly, grey PMD under the bumper, new turbo waste gate solenoid. There are no fault codes. If you go without traffic jams, that is not you press on the brake, then everything is fine. After stopping at a red light, if long, the machine starts to blunt, sometimes I tapped his toe on the brake pedal with the other side, it seems to me that to get better. Now the question I came back to the issue of the brake booster, can be restored amp bad? If pytalsya take what is new, or try again restored? When answering please note that sending me to Russia is very expensive.
