jrsavoie
Recruit
I need to check the flex hoses on the 2006 Jeep Liberty.
If I am in need, are there flex hoses better or worse than others?
I'm looking into ordering one of these Motive Bleeders.it should all be straight forward, might have a caliper bracket that has to be removed to get the rotor off if going that far, but for the most part just use a small pry-bar to open the old caliper a tad to allow it to slide off easily. open the MC and keep it full allowing it to gravity bleed and you should be golden!
Might need some special tools like a torx socket for the bolts.
