Braided Stainless Brake Hoses and Stainless Brake Lines
Hydraulic shop or race shop should be able to fab them for you.
Bring the stock rubber high pressure lines to them for measurement and tell them to replace the rubber with steel braided lines.
Yes on the pre-fabbed stainless hard lines. I only intend to do this once, so no need to play around fabbing them myself. This will probably get installed around the Xmas or New Year Holiday. By then my brake system fluid will have been changed out at least 3x.:rolleyes5:
Already done it, Inline Tube pre-bent fit like the proverbial glove, there was only one incorrect bend on rear line that I encountered and it was easily dealt with plus IIRC I reported this to them so hopefully it has been dealt with.
If only everything truck related went as smooth/quick as installing these lines, for the price you pay you cannot beat this solution.
Cheers
Nobby
