Bought a turbo boost bolt, now which gauge?
natjwest
Portland, Orygun
I bought a turbo boost bolt from pmdcable.com but I don't know what kind of gauge to get. One that goes from zero to 35 psi or 30 In Hg/20PSI or 2.5 kg/cm2 or...? totally confused.
Can someone look at this page and tell me the right type of measurement to get?
egauges.com/vdo_mult3.asp?Type=Turbo_Boost&Series=Sport_Comp
ATM-3301 or ATM-3303 would be fine for the 2 1/16 pod/gauge mount and the ATM-3301 could also double as a vac gauge for testing purposes on the vac pump/wastegate system.
If you have the 2 5/8 gauge mount then ATM-3403 or ATM 3404 would be fine from that list.The ATM 3403 could also double as a vac gauge for tests.
If you not boosting over 15psi I would recomend o-15 psi gauge. Will make the gauge easier to read.
Thanks again for the purchase.
