bosch glow plug
atvhauler
ontario
I bought a set of bosch duraterm glow plugs part# 80034.I notice that the overall length is long then the delco glow plugs.Also the glow tube length is shorter.Is this normal?
Will everything fit ok?
If you are putting it in a 6.5L diesel, it should fit.
I installed Duraterm a few years ago and it goes in without any issue.
It uses 10mm socket as suppose to 3/8" for ACDelco.
