onewayjay
My local parts store has Borg Warner reman injectors for less than 20 ea. Just wondering if anyone else has used them, and if they are worth trying?
Less than $20 per injector no core? What is the warranty? As long as you can get $ back in 1 year I would try it. Very first sign of hiccup I would yank them before a stream puts a hole in the top of the piston.
If you have a pop tester then its no problem. 2 things I would sweat is streams and uneven pop pressures.
