Boost Gauge Problem and hard starting
billky
Kentucky
Thanks guys for your help and information. Recently installed a boost gauge with boost bolt replacing bolt in upper intake, but have no readings.With bolt removed completely no change in engine when running. Recently having problem with hard starting warm weather or cold makes no difference. I posted these earlier but was advised by JiFaire to complete this check list and attach.
Problem: Explain your problem in concise language (ie: Cranks but won’t fire). ___Hard starting and no reading at newly installed boost gauge._________________________
- Year: __1995____
- Truck model and class (ie: c2500) _______K2500__
- Automatic or Standard _______Automatic___
- Mileage: (indicate miles or km) _____162,000____
- Replaced parts and mods (IP, PMD, chip/PCM, TM, injectors etc) ________PDM, harmonic balancer,turbo boost solenoid, vacuum lines from wastegate and vacuum pump___
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? ___s model turbo___________
- Ambient outside temp: (indicate *C or *F) _30 to 60 F_________
- What fuel are you using? (#1 Diesel, #2 Diesel, Bio, VO, WVO, etc) ______#2 Diesel___
- What fuel additives are you using? _Stanadyne__________
- Where are you located? ________Southeastern Ky_____
- Air filter ___159,000______
- Fuel filter _____161,000____
- CDR Valve? _________
- Coolant – last flushed/replaced at __________160,000___
- Oil – synthetic/regular, changed at _______160,000____
- Batteries – state of charge, (matched set) replaced at _____________
- Battery cables and grounds (removed, cleaned and tightened): ______________
- Glow Plugs - how many miles on them? ___Not sure______ What type? ___Not sure__________
- Injectors - last changed at ___Not sure____________
- What were you doing when it happened? _________When purchased_____
- How was the truck running fine before this problem appeared? _______Runs fine after starting______
- Has this problem ever happened before? ________________Yes_______
- Describe any related factors that might be part of the problem. ______________
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) ___N_ And? ________
Diagnostics:
1] Starting:
1a] Does the engine start? ____Yes_____
1b] Does the engine crank over? __Yes______
1c] Are your batteries fully charged? ________Yes_
1d] Have you removed, cleaned, and tightened all battery connections? ____Yes____
1e] Does your Wait to Start light come on for a time? How long? _______No__
1f] Does your glow plug light come on? _______Yes__ For how long? __2 to about 10 seconds_______
1g] Do you see smoke from the exhaust while cranking? What color? _______Yes, white_
1h] Does the Service Engine Light Glow during Start/bulb check? ____Yes____
2a] Can you hear your lift pump working? _______Yes, replaced_____
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? _____Yes____
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? ____Havent checked yet_______
2d] Loosen an injector line and crank the engine - does fuel come out? _____havent checked yet____
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? _____No______
3] PMD / IP Issues
3a] Location of PMD (on pump, on intake, remote mounted) _____Just under front bumper inside grill______
3b] Condition of Extension harness (if used) Vendor or Homemade? _______Vendor__
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. _____Not checked yet____
3d] PMD Make: ___________
3e] PMD Age: ___________Not sure, changed before I bought it__
4] Stalling Issues
4a] Do you experience stalling only when hot? __________
4b] Does it stall under particular circumstances? (ie hit bump, or on accel) ______
4c] Does pouring cool water over the IP seem to help with restarting? _________
4d] Is stalling momentary (engine recovers)? _________
4e] Does SES light come on when engine hiccups? _________
4f] Does cruise control quit working when engine hiccups? ___________
4g] Does re-starting seem to reset engine, restoring cruise and power? _________
4h] Changes to dash lights or instruments during stalling events? ___________
5] Running Issues
5a] On cold start, does upper rad hose get hard before engine warms up? ___No____
5b] Any bubbles or oil film in coolant overflow tank? ___No____
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? ____No______
5d] Excessive white smoke from exhaust on cold start? ______Yes___
5e] Excessive black smoke from exhaust under hard acceleration? ______No____
6] Performance Issues
6a] Do you have gauges (boost, EGT) ? ______Yes, boost____
6b] Maximum boost under load? ______No reading, just installed______
6c] Have you added a performance PCM (reflash) or Chip? _________No_____
6d] Have you changed exhaust / downpipe / crossover? __________No______
6e] Wastegate – mechanical or vacuum (OEM)? __________Vacuum____
7a] Single or dual thermostats? ___________
7b] Have you replaced them lately? Manufacturer of replacements? ________
7c] Have you pulled and cleaned Radiator and coolers lately? ____________
7d] Have you replaced the fan clutch? Manufacturer of replacement? ________
7e] (winter) Have you tested your antifreeze? Good to what temp? __________
7f] (winter) Are you using a winter grille cover? ___________
Ok quick read thru the diagnostics, white smoke during crank & cold weather generally indicates a glow issue, lets work that before going to the no boost issue. What have you done to trouble shoot glows ?
Actually I haven't done any tests. Just looking at the glowplugs without removing them, it appears they have been in the engine for a long time and I was planning on replacing them. Any suggestions as to what brand? The weather here only gets down in the twenties or lower about 2 months out of the year.
Thanks Chief.. I am in the small town of Hazard, about 110 miles southeast of Lexington, Ky.
Even the 6.5 with it's high compression needs glows for reliable starting, and for a Diesel with some age on it even more so <60 F is cold and will hamper starting, so healthy glows are a must IMO. As are healthy batteries, cables & starter.
